The end result of the ruler trick, additional polishing and refinement right at the cutting edge on the flat side, is the natural outcome of stropping on flexible media like leather, even some 'hard' rubbers give enough to produced the same effect. No lift is needed on one's finest stone. If one does feel a little lift is necessary then do it on a firm strop charged with a very fine powder. A few passes is plenty. There is no need to produce a bevel on the flat side at one's fine stone. The desired effect is achieved well before that much metal is abraded and this includes even the finest of back-bevels.
Honing past the so-called 'wear bevel' (fancy name for dull-ness) should be done only from the beveled side of the iron.
Once the flat side of a cutter is flattened and polished it needs no further work other than regular backing off and stropping. If the strop is flexible at all then fine polishing takes place all the way to the cutting edge when both sides are worked.
