mickthetree
Hi all
I got a 5/8ths" OBMC delivered and cleaned it up.
I now just need to grind a new primary bevel (30 degrees I think).
Is there a method I can use to work out how much the blade should project from my eclipse guide to get said angle?
Does it matter the thickness of the blade? and is this part of the equation?
Sorry if this has been discussed before, but I couldnt find anything. Maybe using the wrong term.
I was just going to set the guide from my other OBMC which has a bevel that cuts nicely, but wanted to see if there is a method for working this out.
Cheers!!
Cheers!!
