The circuit breaker if its an MCB needs to be class C rather than a domestic class B. The difference is that it allows a longer time for the initial surge of current when the motor is turned on to occur before it trips. The common fault is to use a much higher rated class B MCB to achieve the same effect. However, this would mean that you would have to upgrade all of your wiring, connectors etc to the same rating or higher than the MCB. The fuse is there to protect the wiring / circuit not an individual from electrocution. I.e, to prevent a fire.
You will probably not need any more than a 16A class C. But check the machine handbook for the specified rating. I have th 16" CP Sedgwick P/T running off a 16A class C without it tripping. This enables me to use standard 16A plug connectors.
