Carpet gripper on top of the wall . Smeared with excrement - nothing like a good infection for the thieving scumSpiky walls seem appropriate. Barbs. Poisoned tips.
What are you going to do when the alarm goes off ?
Run out side and get stabbed .
The problem with the wall height is that my land is about 1.5m lower than my neighbours. Which means the wall would be about 4m high in some sections and block loads of light coming into our garden.If possible can you raise the height of the fence / wall between you and your neighbour? Add trellis panels to the top? He has to understand after two break ins.
There's so much scum out there, really feel for you. I have Hubble cameras that work from Internet, so even when I'm on holiday, (you remember those days!) I can just check in on things. They alert me on my phone noise, movement. The sensitivity can be set so you don't get the bloomin spider that kept telling me he was spinning his web alert! Also got Ring door bell, this captures anyone hanging around maybe casing the place. I have a lovely clear video of a guy nosing in our back garden (before our gate was replaced,) a couple of years ago. My dream would be handle attached to 24v lorry battery but apparently it's illegal!Well, after building my workshop over the past few months and sorting out all my tools (with a french cleat system), it seems I turned it into a veritable palace for some thieving b******s who broke in last night. Seven power tools were taken and I'm now looking at beefing up the security (was a single padlock on hasp) and keen to take any advice to prevent this happening again when I replace the tools.
So far this morning I've ordered an alarm and an extra door defender to block the double doors to the front.
Any tips/ideas welcome - I'm contemplating leaving my german shepherd in there overnight tonight in case they decide to return for more of my tools.
Cool. Our neighbour's cats go all over and around my garage, would that set the sirens off?Best thing is an alarm that will go off before they get to the building. I have beams and slot pirs. Can't get within six to eight feet of the building without all hell breaking loose, whole set up cost about £100. Ditch the rubbish siren that comes with most of them, I have mine wired to a 300db airhorn. Just make sure you set carefully up to avoid false alarms, otherwise you will be unpopular with the neighbours.
Similar problem in that I have a couple of small dogs. The beams are set about 4 foot off the ground. The slot pir, also called curtain pirs, sense over a narrow horizontal plane. Again mounted about 4 foot up so the dogs are underneath the sensing area. Cats might be a nuisance to the pir, but the beam sensors have to be broken directly so shouldn't be too difficult to set them up so the cats can't break the beam. You can make your own slot type pir sensors. If you get a standard sensor designed to control lights, 12v input/output. Get some plastic 25mm pipe conduit couplers. These fit neatly around the sensor lens. Now hear up one end of the coupler with a hot air gun and squash it flat into a fishtail shape. Put a piece of wood or metal in between the sides to determine the width of your slot. Now you can place it over your sensor and you have a narrow sensing area. Varying the length of the tube will vary the sensing area. You can test it by just rigging it up so it activates a bulb so you can judge the sensing area you have and adjust your mask accordingly.Cool. Our neighbour's cats go all over and around my garage, would that set the sirens off?
