TheTiddles
simdel1":1rxt0tqp said:Got it clamped up after work today. Fingers crossed!
Are you a mechanical engineer per chance?
Aidan
AndyT":2d7gnlfi said:It's always nice to see someone finding ingenious solutions to problems when working with a few basic tools. Well done!
TheTiddles":2d7gnlfi said:Are you a mechanical engineer per chance?
Aidan
simdel1":lbgkugh4 said:After shaving the hinge area smooth (still using the knife!) I drilled some pilot holes and fitted the hinges to the main body of the box.
simdel1":go9fyf1z said:AndyT":go9fyf1z said:It's always nice to see someone finding ingenious solutions to problems when working with a few basic tools. Well done!
It's almost theraputic going into the garage to cut some wood after spending a day chasing after diesel engines.
RussianRouter":950d3f7d said:Hi simdel1
Nice work for an ametuer,however forgive me if I correct something but...those hinges are the wrong way round,does the lid close flat at the back or is there a gap between lid and lower box?
simdel1[quote="TheTiddles":je42om1e said:Are you a mechanical engineer per chance?
Aidan
frugal":xvevglo9 said:If you want to make the hinges a bit special, buff them up with a couple of grades of wet and dry sand paper, and then some Autosol or Brasso on a rag. Do the same for the screws. That will make standard hinges pretty special without taking much time and without any outlay for extra tools
RussianRouter":xvevglo9 said:Edited: My apologies they're the right way round,just badly made hinges and nothing to do with simdel1's work.
Chems":xvevglo9 said:those hinges look so neat
Einari Rystykaemmen":xvevglo9 said:this butt-hinge type is not so good for boxes as it leaves gap between lid and chassis
simdel1":3h032hrn said:I'll probably try to build that edge back up with wood filler.
simdel1":1jcw4bgl said:RussianRouter":1jcw4bgl said:Edited: My apologies they're the right way round,just badly made hinges and nothing to do with simdel1's work.
Yes, these are very badly made hinges! You might find it hard to believe, but I actually went thorough the entire selection of hinges on the shelf trying to get a pair that matched in terms of surface finish, hole location and counter-sink depth. That's what I get for buying hardware from wilkinsons! As this is only a 'practice' piece, I dont mind having rubbish hinges though.
