Scrub plane
cwroy
25 Apr 2007
Montreal, Canada
Hi,
I've just bought a ECE wooden scrub plane. It works wonderfuly, and right out of the box.
I haven't sharpened it, it's just ground from the factory. Plows through the wood as if it was butter.
So there is my question.... Should I sharpen it, and to what extent???
Thanks for your advice.
CW
Great little plane.
If it is working well for you, I wouldn't bother sharpening yet. Being a scrub it will get a lot of abuse, so it won't be long before you have to sharpen it properly anyway.
Karl
Yes; in scary sharp terms, I'd go to around 1200-1500. This is overkill in terms of edge sharpness, but coarser edges tend to degrade more rapidly, due to fractures starting at the "notches" (on a small scale, of course).
IIRC Jeff Gorman used to have a citation to research in this area but his site's no longer up.
I would recommend a convex (or very narrow) wheeled jig for honing, and a final bevel of around 35 degrees for strength.
http://www.geocities.com/plybench/scrub.html#blade
Others will be along shortly to tell you to freehand it.
BugBear
Yep. Don't bother with a microbevel. Huge reference surface - a cinch to freehand. Just roll laterally through the stroke or do it sideways.
(My #43 is much more amenable now - thanks BB)
Steve
If you like using honing guides, I find the Veritas Mk2 with cambered roller very good for honing scrub-type blades. You only need hone about two-thirds of the width of the blade as only the central portion of the blade tends to be projecting.
Cheers :wink:
Paul
Cheers :wink:
Paul
Although you do need to work the whole perimeter, otherwise you'll eventually lose your camber!
BugBear
bugbear":37jzebw2 said:
Cheers :wink:
Paul
Yes, but that will take quite a while, by which time it's probably ready for a re-grind anyway.
Cheers :wink:
Paul
