So you hadn't considered attaching the planer to an extractor? Or working outside? That solves the dust problem. Wearing a mask for hours at a time is only necessary if you have rubbish extraction, Mike, so it's something worth sorting out for anyone who uses any sort of machinery. And sorting out extraction gets rid of a lot of the "decontamination" issues. What I don't understand is the tear out problems you had. I just can't see how you got them. I sometimes use a power planer to take-out high spots on warped boards and 3 one millimetre passes is much better than one three millimetre one any day. You also have to change the technique and plane a bit nearer to the direction of the grain - that way with sharp cutters you have minimal tear out, and what there is taken care of on the planer/thicknesser. And in some cases wetting the surface can help with wayward grain, too. Despite what you may think there are techniques to deal with this.Midnight":2w71kg9o said:Biggest waste of time n money was the hand held electric plane... within 10 mins of using it the air in the shop's so thick with dust that ya canna see what you're doing... abandoning the shop for an hour to let the stuff settle followed by a 2 hour decontamination of the entire shop is hardly an effective use of your time; wearing a mask for that kinda time gets long in a hurry.!! Once that's done, then you need to deal with the tear out the damn things leave behind which can be just as deep as the few passes they've made... frustration happens...
Different strokes for different folks
If it makes any difference timber buying is the one area even for use trade types where caveat emptor is the watchword (watch term?). Some of the rubbish that some yards try to palm off on you is amazing, and if they don't know you or think that you're an amateur then they regard it as open season....... But there are good yards, too. For example I've never had a bad board off John Boddy, not the cheapest, but their stuff generally has less waste on it so in the long term can work out cheaper for meMidnight":2w71kg9o said:My 1 experience buying stick from a yard would keep the likes of Scrit chuckling for a week... you don't have monopoly on being a rookie.. trust me..I suspect its all to easy to be taken advantage of a tad.
Scrit
