Got a scroll saw earlier today,and all was well. Been playing with it and learning how to change bladesmand whatnot.
So changed the blade, tensioned up, cut then when I went to change the tension, it would not alter.
The tensioner turns but doesn't change the tension, and it is now set on high.
I have tried to gently push on the arm, but nothing, and have removed the side plates and checked and everything seems OK.
The only thing I can think is the lower part that looks like it should move when the tensioner is twisted is most working, but I didn't tension it overly high and did have it a couple of 'notes' lower when pinging it.
So as it looks quite simple, is there anything I can do? It does work, but the tension cannot be changed :-(
It is an old axminster yellow one, cbfs I think.
