Trainee neophyte
This is sort of wood related: on my list of very important jobs, somewhere near the top, has been the manufacture of a scratter (apple annihilator/pulper, for those who don't make cider). Up until now, I have used a small, Italian wood chipper to do the job, but it is not at all appropriate. Firstly, metal should never go near apple juice if you can possibly avoid it, as it can discolour the cider, by taking up iron. Possibly healthy, but gives the cider a greyish hue, apparently. This has not been a problem so far, but there is a lot of metal in a wood chipper. The chipper is also slow, noisy, leaks pulp (and juice!!), and not at all designed for the job.
Secondly, all the internet people seem to say that turning your apples in to baby-food consistency is bad - you should have small chunks of recognisable apple, not purée. You get more juice from the former, apparently.
So, this year I borrowed from a friend what is a close approximation to a scratter: the internal workings look like this:
It did a beautiful job of cutting the apples - the hopper takes an entire crate, unlike the chipper, where you feed the apples in one by one, and the result was perfect little chunks, just as the books all say you should have. The problem was - no juice! Here is a picture of the difference in post- pressed pulp. Red crate shiny new toy, blue crate
chipper.
It was the same weight initially in both cases, but you can still see the bits of apple in one, whereas the other has just dry, fibrous mat - as it should be. The difference in efficiency is quite a suprise, too. I put 4 crates of apples = 80kg (or a bit less) into the press, and expect to get around 45 litres of juice, so around 55% juice. Not brilliant, but not too bad, as I only have a 1.5ton bottle jack, of dubious efficiency, doing the work. However, when using the shiny, expensive new electric scratter, 45 litres was down to about 20, so around half the juice was left in the pulp. Not good.
Here is a gratuitous photo of the press all loaded up and ready to go. NB this is the first of the day, so everything is clean and tidy - after 2 days, we are all looking a bit more disheveled and sticky.
And here is a photo of a freeloader who turned up to eat some apple pulp dropped on the ground. He is trying to make a surreptitious escape, as you can see.
So, the reason for this post: has anyone made/used a scratter with good results? I will keep using the chipper even though I hate it, if it gives more juice. The romance of having a nice, wooden scratter to go with the wooden press is less important than having cider - 2 full days of effort for 600 litres is enough; if I only get 300 litres, then it's going to be disappointing, although the pigs will be happier, as they get better quality pulp.
chipper.
