graduate_owner
It certainly is possible to make your own scratter, I made one when I was a teenager, and the only power tool I had was my dad's electric drill.
The design came from a book published by Amateur Winemaker, called Woodwork fot Winemakers by Dart and Smith. Basically it is a square wooden box, no top or bottom, with a series of plywood discs mounted on a square shaft. The discs are slotted at 120 degree intervals and a nail is glued into each slot - the slots are staggered which helps to feed the apple in. A ram is fixed at the top, the juice etc comes out of the bottom. It worked very well.
Since then I have made a bigger version, using the lathe for the drum and stainless steel screws instead of nails, but same principle. I suppose you could improve by having 2 counter rotating drums, motor power etc, but my hand driven version suits me.
If you can send me your email address I will scan the relevant book pages if you want
K
K
K
K
