scrapers and oak
pitch pine
3 Jul 2007
northumberland
I am making a small table top out of oak. It comprises 3 edge-jointed boards and is 20" long and 14" wide. The boards are 22mm thick. I did the edge jointing OK and glued up, but when I tried to true up the face side I just couldn't do it without quite deep tearout (2-3mm). The grain changes direction on all 3 boards and even with a sharp plane and always going with the grain I couldn't avoid it........so I tried a scraper. I haven't had much sucess in the past but this time I managed to get reasonable shavings rather than dust. This left the top without tearout but with hollows from scraping.....so I sanded and got it reasonably flat.......and then I thought maybe I could have skipped the scraper altogether!
Question is are my expectations for the finish on this kind of oak with a scaper too high? I was hopeing to minimise the amount of sanding I had to do. Any comments?
Nick
I've found a scraper plane to be the best bet. That way you will avoid creating hollows (as you have done with a scraper card). They're not cheap though, but you could always make your own. There was a recent thread on doing so recently.
Alternatively you could try a back bevel on your bench plane of around 15 degrees (assuming it is a BU configuration). And take a very fine cut. This will only work if your plane is in good working order though.
Karl
Oak can be tricky for tearout at times and Karl is right that the scraper plane is the best solution. I use a small LN 212 scraper on isolated areas which means you don't need to scrape the whole board but can avoid too many hollows.
Ideally I would like a LV scraper plane, which I believe is acknowledged as an excellent tool for the situation you have.
Cheers, Ed
Paul Chapman has recently finished a table top in oak (even though there are no pics :wink: :lol: I can personally vouch that it's been done) and he used a LV scraper to finish it, which I know he highly recommends - Rob
so you are suggesting I buy more tools.....I like that, I simply haven't got enough planes yet. Has the scraped oak table top needed any sanding?
I have done this so many times that I reckon I have cracked it.......
Plane 45 degrees across the grain (scrub planing, I think??) a bit if necessary, then belt sand across the grain then with the grain and through the grades.........and then finish with a scraper. Thats the key.......the scraping comes last on a flat surface, and you achieve the flat surface without planing with the grain because of the tear-out issues.
I am just contemplating making a scraper plane for this very situation. I have to say that I find English oak less prone to these problems than American White Oak, and can often finish just with a plane.
Mike
Mike
AWO is a very difficult timber to work with and often needs scraping to finish - Rob
Here's the table top before scraping
And here it is almost finished
I used the Veritas scraper plane which I think is a fabulous tool. The finish it leaves is good enough not to need sanding. I also have the Veritas #80 style scraper which is good on smaller work.
Cheers :wink:
Paul
I'd go along with Paul's recommendation, he posted those pics when I was umming and ahhing over scraper planes and ended up with the LN version of the 112. Good plane
I'll second what Paul says about the LV scraper plane as well, or should I say third it :lol:
Unbelievable finish is achieved and it's so adjustable it will scrape anything. Definitely one of the best tools to come out of Lee Valley.
Cheers :wink:
Paul
I used Paul's LV No80 scraper last year at Pete's (Newt) and was very impressed with it...it's far better than the original Stanley - Rob
Thanks for that. Looks an excellent finish. Do you use the scraper plane in the direction of the grain and "uphill" like a bench plane?
Generally yes, used in the same direction as you would do for a bench plane. A bit of trial and error though will soon show you the best direction to use it it - Rob
As Rob said, it's probably best, if you can, to use the scraper plane in the same direction as you would a normal plane, but in practice you can usually use it either way. With something like a table top, you will often arrange the boards (8 in the table I was making) to suit the appearance rather than the grain direction, so the grain is likely to be all over the place. With the table top in the picture above, I scraped the whole top in one direction.
Cheers :wink:
Paul
Paul,
I wonder if you could let me know the blade dimensions on your scraper plane? I am just starting to think about making a wooden one.......
Mike
Mike Garnham":b77u7fju said:
Paul,
Mike
Now this looks promising...could be 5 planes shortly. Top of the 'Slope' maybe? :lol: :lol: - Rob
Just need to pop over with the tin of grease, don't think I even have to shove him. :wink:
Steady guys!!! Admittedly, going from 2 planes to 3 is a 50% increase........but it is hardly an obsession! A scraper plane, plus one long thing (a number 7 maybe) in the next few years and I shall feel uncomfortably overwhelmed. That is the limit of my slope!
Mike
I'll measure it tomorrow and let you know.
Cheers :wink:
Paul
