Saw blade for Oak
lloydy123
New member
28 Oct 2016
Northern Ireland
Hi,
I am fitting my own house with solid oak skirting, architraves etc. What high quality blade would you recommend for my sliding mitre saw for a fine finish? Size 250mm x 30mm. Freud make good blades, had thought of 80T for a neat finish but they don't seem to make any with negative rake/hook. Is this essential?
Any input appreciated
Thanks,
Lloyd
Not sire about rake etc. but my Freud 48tooth 250mm gives a beautiful cut on some 25mm oak I ran through it recently. I wouldn't have though you need to go anywhere near as high as 80 teeth.
negative rake is not essential, but the saw will want to ride over the timber a bit more.
Im not sure if 80T is necessary, there may be risk of burning with so many teeth, 48 teeth would be fine as otter suggests.
Id be interested to see other peoples experience of cutting with very fine blades on hardwood. I tend to think a very sharp combination blade will cut better than a less shape very fine tooth blade.
Interesting thoughts, I had wondered about using so many teeth on hard wood. I just want the best possible finish, obviously don't want burn! What do others think is the best number of teeth?
nick winfield":o7chxn5c said:
what ever blade you get don't forget to clean it after cutting oak as it will rust
Only if it's wet
If you're prioritising clean cuts then you need to do three things,
- stick with the negative rake that is standard for mitre saws, it cuts with a sheer cut which makes it much cleaner and besides it's just a safer choice on a mitre saw (but dangerous on a table saw)
- use a dedicated finer blade with more teeth
- make yourself fresh zero clearance inserts for both the bed and for the fence
Personally I think you may be a bit too focused on cut quality for skirting boards rather than say mirror frames or moulding mitres, but it's your project so you get to pick the priorities!
Good luck!
