brucew
I've been using a track saw the last couple years for DIY work and recently changed to Freud blades (165mm, 1.7mm kerf) because they are so widely recommended. Yet, when I take an edge off of thick oak, the blade starts to struggle halfway along and drifts outward even though my saw track is still in place. I checked & tightened the saws track-fitting knobs but still have that problem.
Could it be that the Freud blades are too thin and the blade is deflecting? If I move to the middle of the cut and plunge straight down, it stays on line. If I use my cheaper 2.6mm kerf blade, it cuts straight.
