murphyabu
Morning all,
I have been visiting your threads and using them for research over the last few weeks as I am looking into buying a table saw,
I currently have a El Chop saw (Hand me down) which is a great bit of kit,
I've also got a Dewalt Circular Saw,
Having just moved into a new house there are a hundred and one tasks to be carried out, stud walls to be put up, cabinets to be made, idea furniture to be adapted to prevent it falling apart etc
At present a lot of the cuts I am doing involve ripping down sheets of 18mm ply/mdf for shelving and alike, for those types of cuts i am using the circular saw with a straightedge as a guide, however as you know this often leaves quite a margin for error,
This brings me onto the subject of table saws,
I have been looking at the Dewalt/Makita Flip saws but then started looking into dedicated table saws as I already have a working chop saw,
I've a budget of around the £400 mark and I'm looking for a saw I can use for ripping plywood down to size whilst also being able to make fine cuts for use in cabinets, so accuracy is important,
At the moment I've a shortlist of;
Woodstar ST12
Jet JTS-315
DW345
Axminster TS200
The plan is to use the saw initially on legs/temp workbench before finally integrating it into a workbench on wheels which can be maneuvered around the garage and out onto the driveway etc with removable exit tables etc.
What would be your saw of preference from the above and do you think there's another make/model I may have overlooked???
Thanks in advance for your help
Woodstar ST12
Jet JTS-315
DW345
Axminster TS200
