Lawrence wickham
Hi I have a Axminster dual drum sander does anyone know where I can get the rolls of sandpaper for it which is cheaper than Axminster price which is about £40 a roll thanks
Does it take 102mm wide loadings? My solution for my 16-32 was to buy rolls of 6" P120 from EFA which are now very cheap. I made a jig for cutting this lengthwise so out of the 50m roll I can get at least 40 loadings . You could try something similar with 115mm rolls.Hi I have a Axminster dual drum sander does anyone know where I can get the rolls of sandpaper for it which is cheaper than Axminster price which is about £40 a roll thanks
Brian is your machine a Laguna 16-32?Does it take 102mm wide loadings? My solution for my 16-32 was to buy rolls of 6" P120 from EFA which are now very cheap. I made a jig for cutting this lengthwise so out of the 50m roll I can get at least 40 loadings . You could try something similar with 115mm rolls.
Brian
Brian
Mine is an old Jet. I just cut the 6" down the middle and that provides 2 loadings that replicate the original design. The problem with the EFA products is that they only do 120 and 180.Brian is your machine a Laguna 16-32?
Do you split the 6" into 2 x 3" or will it fit as a 6"?
I buy in 3"120g rolls but they are more expensive than 6"
