Niki":2xlbb7fa said:If the little voice inside you tells you "Don't do it" - don't do it, find different and safer way to make the cut.
Excelent advice Niki.
Shultzy":dgec3i91 said:Check out the wood whisperer's site, his last 5 videos are on workshop safety.
To the OP I say this; Norm is a very poor example of safe woodworking. Most engineers look askance at the minimal (some say inadequate) safety guarding on many woodworking machines and with good reason. Taking the safety equipment off is simply increasing your chances of an accident, and even American table saws come with splitter/riving knife and crown guard as standard. If you want some good advice, then read the relevant pages on the HSE web site, here.Tusses":1sio07qc said:I am Norm / Self taught and as such have learned from the start to use a table saw without the blade guard/riving knife.
Mailee, you surprise me. I'm going to ask you a question, here. Why is it necessary to actually see the saw teeth entering the cut? The rip fence itself is the guide, not a chalk line, and table saws aren't really ideal for freehand cutting. Assuming that your rip fence ruler is accurate, that the teeth of the blade are sharp and properly ground and that the timber isn't badly warped just what is it you are looking for?mailee":1sio07qc said:IMHO I find the crown guard gets in the way for a lot of cuts I do, grooves, tennons etc. I do treat the saw with the respect it deserves as I know they don't take prisoners. I always wear safety specs and use a push stick.
Perhaps, but just because you haven't experienced one for a while doesn't mean they won't happen. "Common sense" says stay out of the firing line......... well if that's the case doesn't it also dictate that you use a machine with all it's safety equipment properly adjusted and in place and that you gen up a little on safe practice before using the machine?Digit":1sio07qc said:The HSE could make climbing into bed sound dangerous! I haven't had a kick back for so long I can't actually remember the last one.
Common sense and stand out of the firing line.
What you are referring to, mailee, is a procedure called "deeping". If you are doing this on a table saw then your table saw is probably inadequate for the task you are trying to make it perform and you should, if possible, find a safer approach such as using a bandsaw or even a jigsaw...... Inappropriate choice of machinery is often a contributing factor to accidentsmailee":3ty85l2u said:It is not a case of seeing the blade teeth Scrit just a fact that I can't make a cut halfway through the thickness of the timber with the crown guard on. I acknowledge that the crown guard is a good and necessary safety device for rip cuts or cross cuts to length but is only useful for this type of cut.
I'm always curious when people state this. For a while I did a bit of work for an insurer and blaming accidents on safety equipment failure was a recurrent theme. Only rarely is it found to be the case, so I'd really like to know what your failure was. For the record I'll reiterate that I've had 13 stitches in my left thumb (22 lacerations) and reconstructive surgery on my right thumb - both were pin router accidents and neither was down to any form of safety equipment failure.Digit":3ty85l2u said:I do Scrit. I mangled two fingers due to the failure of a safety device so I'm well aware of the dangers.
WhiskyFoxtrot":3neux2it said:Hence the need for a unbreakable push stick(s) at least 12in long.
OPJ":1tcygmlf said:WhiskyFoxtrot":1tcygmlf said:Hence the need for a unbreakable push stick(s) at least 12in long.
450mm/18" is a lot better. This way, your fingers should be 300mm/12" away from the blade which is much better than only 6"!
All this talk about deeping is interesting. I'm pretty damn sure it's an illegal practice in industry and yet I used to work for a company who bought timber (even 3"x3" section) where you can clearly see it had been cut like this!
mikepooley":3okhhal3 said:Firstly everyone is right you must not remove the guard or riving knife!
Now to tell you what i do !!
sometimes i have to cut 4 inch boards down so i do this by passing the work over the blade twice with no crown gaurd and the riving knife set to be level with the top of the blade.
this is the only way i can work out how to do it unfortunately.
I have taken to leaving the riving knife in this position as its so much faffing about to keep altering it but this makes ripping say a 2inch+ timber difficult as i cant get the crown gaurd on.
I dont like this so i am thinking of getting one of those cantilever crown gaurds from axminster. the ones with the built in dust collection.
at £99 its a bit dear so has anyone had experience of these before i get it?
thanks
mike
I'd say that was damnably poor design. I'd have thought that failure should always be to the "off" or "safe" position in a properly designed piece of kitDigit":1slns5rv said:How about a micro switch that failed to the 'on' position Scrit? Would that qualify?
