Safely removing quite a lot of material from a block of wood
dance
11 Oct 2010
North Yorkshire
Hi
Today I was faced with this, at face value, quite simple problem.
How to remove a lot of material (30mm worth) from a block of wood you can hold in your hand...but leave a 12mm lip.
I've attached a picture to better illustrate this!
At first I tried routing out the material, raising the router bit as I went, but I realised this was dangerous and so stopped.
Then I tried trenching with the mitre saw, but whilst this worked, it was fiddly, time consuming and still left a lot of work because the curved saw blade left a concave trench in the wood. The table saw might have been another option but I didn't think it was safe because of how small the wood was.
Any ideas?
    29.3 KB
what tools do you have, and what length is the timber?
as long as it wasn't too short, i would probably do it on a table saw, or router table
Length of wood was 95mm, thickness 45mm, width 110mm. So, as I say, possible to hold in your hand, and feels a bit frightening to use on a router table.
Thinking about it now, I think I should have used the bandsaw. Although it wouldn't be as precise, it would have been a lot safer and quicker.
Note to self. Run through all available machinery in your mind next time.
Fillister plane
or
Backsaw (for stiffness) for cutting to depth along the lines + Chisel for finishing
I'm sure there are more ways
Wood held in a vice, of course.
Of course a hand saw is the obvious safe answer, as GLFaria has said. You can't rely on power tools for everything.
Quite. I had that thought whilst I was struggling.
Got there in the end. Thanks for all the suggestions. Back saw is another good (obvious now) one. :) ](*,)
Table saw to put in a series of parallel cuts then knock off the waste and chisel flat. Or router table, band saw or hand tools.
You can do things like this quite safely over a router table and other machines if you use two push sticks. It takes a bit of practice but it becomes second nature after a bit. The biggest risk is to the workpiece or the sticks, or kick back, but your fingers stay safe.
But I would have done it with hand tools and/or band saw.
phil.p":ah751eox said:
Why? You've only to cut once then turn the block over and cut again?
Agreed Phil, but it's a fiddly little piece. You're probably right.
mseries":33xjgjz7 said:
I'd use my router table and a push stick. If you are less confident you could make a custom holding device
How much material would you try to take off in each pass? I found the router bit very throwy. Hence my unease with this method, push sticks or no.
It seemed to me like a big rabbet. Just another idea, if you have a portable power planner (most of them have fences for rabetting) remove the bulk with it. Then fine tune with a rabbet plane.
Needed the exact same thing last night, pondered a while on the best way to make the cut with the timber vertical, didn't feel safe running through the table saw. then remembered bought a cheap tenoning jig from Rutlands a while ago, knew it would come in handy one day
Marty
