The Restorer
This is picked up from another thread re-LN chisels.
For a long time i suffered with the dreaded rust in the workshop (also didn't help having a leak in the roof that wasn't spotted and happened to be right over the jointers lovely cast iron bed (you can imagine the mess) beautiful woodturning chucks used to rust whether still mounted to the lathe or put away in the cabinet. Something had to be done!
Went on a cabinetmaking course and found the answer - The Dehumidifier- i have two workshops (one for finishing) and both are equiped with dehumidifiers (one £149 with heater from Screwfix, the other £89.99 from the same place). The workshops are also equipped with humidity guages (bought from garden centres, B&Q etc about £5) that monitor the humidity. I tend to keep the workshop around the 65% mark (it used to be nearer to 90%)and have no problems with rust.
The answer seems to be a reasonable level of humidity (65%) with background heating (the main workshop is linked to the house central heating system) This means no rust and warm pleasant working conditions (no more i'd like to go make something but by time i get out there and get the place warm it'll be time to come in).
The other big advantage is that if you place one of these humidity meters in your house or wherever you are making furniture for you will be able to alter your workshop conditions to match and so make furniture that will last without shrinkage or expansion problems. Also if you happen to restore anything that's warped and twisted due to being to near to the radiator, you can reverse this a suprising amount by covering in kitchen towels, damping down and wrapping in cling film (surface finish tends to be wrecked though) monitor how it goes back to shape and the dry it out slowly by decreasing the humidity in your workshop! You can also condition your timber in this way by in effect kilning it by building a dehumidification chamber within the workshop!
Sorry for the long spiel but to summarise;
Humidity 65% + low background heat = NO RUST ON YOUR TOOLS
