Distinterior
Many thanks for the advice Tim. I was advised by Homebase staff that installing Minervaxworktops was "certainly not a DIY job"! I've arranged for Minerva to machine the undermount sink recess and drainage grooves, so that really only leaves four cuts and two joints to be made. Is that beyond the ability of a competent DIYer I your opinion?
With a good quality router & router cutter, an accurate straight edge to act as a guide for your router, good dust extraction wherever possible, a decent quality random orbital sander with the correct abrasives & pads, and a firm & steady grip on your router, you should be fine.
Make sure you meticulously abrade & clean both faces of any glue joint before applying any adhesive and ensure you have all your clamps ready once you apply the adhesive......At this time of year, the adhesive sets quickly and the working time for any adjustments is very short...!
What method were you planning on using to pull the joints together...?
Vacuum clamps are the best option but are expensive for a one- off project.
MDF blocks hot melt glued to the surface either side of the joint will work in a similar manner as I described in my previous post, then clamps applied to snug the joints up tight......Abrade the surface, clean off any dust with DNA, allow to completely dry, glue the blocks, apply the 2 pack adhesive and clamps.....
