Mike Wingate
Re laser focus. You cannot really use a laser as a milling machine to cut an exact depth. The edge left by a laser is tapered, all to do with the focus. this can be used to your advantage, for inserts, etc.
chris_d":1gdui4p8 said:I'm in and happy to drill my own router mounting holes.
BTW - I'm surpised that cutting the 50mm diameter inner ring is markedly more expensive than the 30mm since I doubt they could accurately/reliably measure the additional energy used by the water jet compared to its startup/ramp-down overhead. Also, with the 50mm ring, they get more waste to recycle!
Cheers,
C
Matt_S":2za58t9j said:A dumb question, why would you need 2 or 3 inserts?
RILEY":3oaavlv7 said:Dibs, at that price, I think you could probably sell them wholesale!
Adam.
