Dibs-h":ewh9ywij said:
On the subject of mounting holes - if it is left to people to mark and drill their own holes - then issues of whether rings are concentric come into play. Now since the laser cutters can engrave as well as cut - I feel that the mounting holes for most routers should be engraved\marked on the plates by the laser and the user can drill out which ever ones they require. That way issues of concentricity don't arise.
No problem with that, If you are going down the engraving rout then concentric rings on the back to assist with routers with non standard hole patterns would be a good idea
On the issue of lip - I was thinking a 10mm shoulder all the way round and having 3 holes evenly spaced to allow the rings to be semi-permanently fitted with machine screws - in the same ways (it appears) that Tony's design does\has. Or is this something that most folk wouldn't want?
I would think that 10mm is excessive, any one else?? do the rings need to be fixed? But whatever works is OK.
If most peep's didn't want the extra ring for the guide bushes - that's fine as I'm sure the cutters cut produce them for us - as long as we had 10 of them made. The way nbrs are going it'll be around 20 sets - so 10 sets with and 10 without - maybe?
As for size - I'm happy to go with 12"x9" - or A4 (297x210), whatever achieves concensus.
