wobblycogs
Please excuse my ignorance but is the shoulder being milled to 3.1mm rather than 3.0mm because there is some margin of error in the plate thickness and milling which shimming with paper will compensate for?
I can see that having the ring sticking up above the rest of the insert would be a bad thing but wouldn't it be easier to lap the ring to exactly the correct thickness? I'm guessing the tolerance on the 3mm plate and milling is less than 0.05mm which I would have thought you could take off with a bit of wet and dry.
