j
Phase 1 of the router table project started with me fitting the insert plate today.
This is the piece of worktop selected for the top
It's a sink cutout from my brother's kitchen. It's about 100x50cm, a little narrow for my liking, but it's free and I'll probably replace it with some full width worktop at some point in the future. At least if I screw it up it won't have cost me anything
To cut out the rebate I used the freud with a 1/2 inch straight cut bit against a straight edge clamped to the worktop. Cutting right to left in the picture so that the rotation keeps the router tight to the straight edge.
Here is the completed rebate, next time i'll mark it with a darker pen so that it's easier to see where I'm supposed to stop on the corners
Next, drill a hole in one corner and cut it out, remembering that the rebate area is the bit you need, the middle bit is the waste.
Now, the moment of truth, try the router plate for size.
Hmm, it doesn't quite look right. The plate is a bit high.
No worries, this I knew this rebate plane from ebay would come in handy one day.
A little tweaking with the rebate plane and not forgetting to clean out the corners where it can't reach, and it fits quite nicely.
I actually over did it with the rebate plane, so my plate is slightly low, but i'm sure i'll be able to shim that when it comes to fitting the router.
I forgot to take a picture of the nicely fitting plate
Tomorrow I'll be fitting the router to the plate, and hopefully start on the fence.
Comments welcome
J
Comments welcome
J
