Deansocial
- Joined
- 30 Dec 2010
- Messages
- 59
- Reaction score
- 0
HPL over here is what you get on a worktop compact laminate(altho the same composition) it 12mm thick
Deansocial":2qoggs9f said:regarding cutting phenolic,
It can be cut with a triple chip blade fine and a router with a tct bit.
Tct jigsaw blades are the best think to cut it with if you want to use a jigsaw but very very expensive. Next best would be the lennox bi-metal blades. I always use a router unless cutting straight line then i use the plunge saw.
Why does everyone on here call it phenolic plastic or just phenolic? I've always known it as compact laminate, that what we buy it as and we do loads of toilets in it every year.
Deansocial":2n6dafef said:you mean the duct sets?
