Router Insert - Interested?
Hobbyshop" Those timings are fine with me. Will you be taking payment through Paypal? Many thanks for taking the trouble to organise this.[/quote said:
The preferred option is BACS, as my bank account isn't linked with PayPal and there are no fees to pay.
Dibs
Hi Dibs
Nov/Dec is fine for me.
Could I be a pain and swap to steel, or would it cause problems? If it does then I'll stick to aluminium.
Thanks,
Mark
Dibs-h":25yibwa0 said:
Steel
1. Orcamesh
2. shipbadger
3. Alex
4. Alex
5. clk230
6. JamesC
7. James J
8. Fluffflinger
9. cutting42
10. MickCheese
11. FuryJohn
12. Luciano
13. Mark Aspin
Aluminium
1. Studders *
2. Marcros
3. Jensmith
4. Hobbyshop *
5. uk woodman
Either
1.??
* - flexible if need be
The one thing I would advise is to find out how long your Bank takes to process a BACS (Internet Banking) payment? Most are part of the Faster Payments scheme which results in payments usually showing as cleared funds in the recipients account within 2hrs. The only exception might be Satander - in which case don't leave it till the last minute, when we draw a line in the sand for payments. Last time - one unlucky soul did! #-o
Dibs
I'm ok either way with timings also. However, this side of Xmas would be good as it's something else to play with in the 'shop over the break :D :D :D
furyjohn
My intention is to do it this side of Xmas.
So the final deadline for reservations is 09:00 on Monday 7 November 2011.
I will be sending a PM to everyone on the list giving my BACS details. The deadline for the payment will be 09:00 on Thursday 10 November 2011. I'll be instructing the cutters on Thursday 10 November 2011. No payment - no router plates. Please note that this second date is the Final deadline. So if you miss the 1st one, with a reservation, as long as you send me a PM and make the payment in time - you'll get your router plate.
I'll be putting up a Google Spreadsheet listing details of everyone's orders, in a day or so. Please note - it is perfectly fine to have Aluminum disc\rings with a Steel plate. This was quite common last time.
Dibs
All
I've created a Google Spreadsheet listing everyone's choices. It is assumed that folk wanting a Mild Steel plate require Mild Steel rings\disc and those wanting a Aluminium plate require Aluminium rings\disc.
There is an additional pair of rings available that when combined allow you to drop a standard router bush in as well, perhaps to close the gap up. These will work irrespective of whether your plate is Aluminium or Mild Steel. This pair of rings will be produced in Aluminium.
Please check the spreadsheet is correct. Please note - I've only filled in Tab1. Tab2 will be updated once payments, etc. are underway.
Please update the thread confirming your entry is correct - or if you would like a change.
The spreadsheet link is at - https://docs.google.com/spreadsheet/ccc ... Vk5ZjRmWFE
Can someone check that it works?
Dibs
Dibs-h":3puvciab said:
All
Dibs
works for me to
Dibs-h":2p0erp78 said:
All
Dibs
The listing is correct for me too!
Can you explain the additional pair of rings more? Presumably these are the "Bush Rings" column on the spreadsheet?
Is there a cost for these and a deadline for ordering them?
Thanks again
Is it possible to order some additional discs, and do you have a separate price for them?
Just thinking it might be useful to make up a couple of close clearance inserts for smaller size cutters.
Hobbyshop" The listing is correct for me too! Can you explain the additional pair of rings more? Presumably these are the "Bush Rings" column on the spreadsheet? Is there a cost for these and a deadline for ordering them? Thanks again[/quote said:
The deadline is the same. Let me know if you want them - I'll dig out the quote and work out the seperate price for them and update the spreadsheet.
Spare rings\discs are no problem. Let me know how many you want - they are just over a £1 something each. Again, will look at the quote and update the spreadsheet with the prices of all the bits. Hopefully do it this evening.
Dibs
Dibs
Thanks Dibs
I would like the Aluminium Insert plate with one 50mm ring, one 30mm ring and three Discs.
works for me too, but could i add an extra 2 discs to the order.
Also, i haven't received a PM with the BACS details - is that to be expected ?
furyjohn
