Router for dovetail Jigs
Moonsafari69
30 Jun 2016
Moira, Swadlincote
I'm looking for buy a new router for use outside the router table, on dovetail jigs and the like. I have a Trend T11 mounted in the table and it's becoming a pain in the b*tt taking it in and out.
What power / size router would be ok for jobs outside the router table work? Would a 600W palm router be powerful enough for a dovetail jig or would I need to get a bigger fixed base unit? I do have use for a palm router so if that would do the job that would kill two birds with one stone.
What do you think?
What size is your jig? I've got the Axminster one and use an old Elu MOF96 in mine, works a treat. Most jigs take 1/4" bits, and to be honest I'd probably find my Mv12 too big and clunky to use on the jig. Stay small would be my vote.
Hi Rick. I have the Axminster jig too. Do you reckon a palm router would be too small for the job? Dave.
Could either of you guys give some feedback on the Axminster DT jigs please?
Hi n0legs, the Axminster jig is good for a low cost piece of kit. It's primarily for half blind DT's but I understand it can be used for box joints too. With a usual amount of initial setting up the half blind's do come out well. It's a bit limited on the width at about 12" but most of the small jigs are similar in that respect. For the cost I do rate it though.
Hmm, I reckon a palm router might struggle on tougher hardwoods. That's only a guess though.
I find the jig really good to use ONCE you've set it up, which was one of the most frustrating things I've ever done in a workshop. I now keep the jig and my router with the bit permanently attached, kept in a drawer. I'd strongly advise making a little right angled setting jug for the lefthand plastics stops, which is on my to do list.
Yep that plastic stop on the left would have been so much better supplied as a metal part. You're right, that does let it down.
Well as I do need a 2nd router I will see what fleabay has to offer and see if I can pick up a cheap 1000w unit. As I do want a little palm router that would quickly bring my total from one to three..... must remind myself to stop there.
FWIW (prob not much), I'm with Rick.
The problem is that you cannot make the cuts in mutiple passes, as you normally might with a low powered router. You need something that has enough power to do this. If you have a bigger router, try it to see. You'll be annoyed if you buy one and find it's underpowered.
Eric, Rick,
Thanks both for the responses, I'll have a look for a cheap router online so I can keep the T11 in the table (plus it's quite heavy to lug around). There's a lot of choice in the 900-to-1100W range, do you think this will be about right?
Moonsafari69":em71th0a said:
Eric, Rick,
Get another T11, then all the kit you already have will be usable.
Bod
Sounds about right. Ref Bod's comment, I wouldn't necessarily get a T11, but definitely worth ensuring they have standard Trend fitting holes.
Opted for a T5, pretty light at 3kg. Saves me buying new sets of bushes etc. Only 1/4" collet but it looks like all of the smaller routers are similar in this respect, it's a sensible price too. Thanks for the help all.
Think you've already done it, but I would suggest aT5. I've used a T3 with the trend jig, and it will work, but the T5 is a better option. I mostly prefer to hand cut now, but the jigs can be useful, and the comb for making box joints even more so.
I also think that is a sensible choice.
You can probably get an 8mm collet for it, which allows the use of a wide range of industrial-quality cutters, and ones that are quite a bit tougher than 1/4" ones. Worth looking around (Wealden sell third party ones, I think but they're not cheap for collets). I don't have one fro my T11 (they are available) but I do for my Bosch 500 & 600 series ones. Tip: if the collets snap in as they do for Trend's bigger routers, buy the collet nut at the same time - relatively cheap and far less awkward than trying to pop out the collet from the nut when you're in a hurry.
HTH, E.
HTH, E.
Thanks Eric, that's a good shout about the additional collet nut. Yes the blurb says it will take an 8mm collet which will definitely be a benefit. Happy with that, thanks again. Dave.
Assuming the Trend collet is just a rebadged version of those for the old Elu OF97, it's worth looking on Fleabay. Got a couple of genuine Elu stock for my OF97 that way at a very reasonable price.
Thanks ****, I've ordered a spare collet & nut already, I found a new set for £10 incl delivery off the aforementioned fleabay. Can't grumble at that. Dave.
