router compass vs bandsaw circle jig
dance
11 Oct 2010
North Yorkshire
Hi
I would like to buy the router compass or built the bandsaw jig.
Does anyone have any tips or thoughts on what I should do?
My thoughts are that the router compass will give a better finish/edge, but that the bandsaw jig might be quicker, safer and quieter to use?
THANKS
I have cut circular holes and circular discs with a home made router compass and I regularly cut circular blanks with a bandsaw.
The former gives you accurate adjustment of dimensions and a good finish of both holes and discs.
The latter, assuming the bandsaw is set up perfectly and the blade is in top notch a jig gives you a reasonable disc but not with the same confidence and consistency of the router jig.
If I want accuracy I use a router jig, if I want a near enough disc I use the bandsaw for quickness with or without a jig.
dance":78ss6euh said:
Paul Chapman":78ss6euh said:
Details here of how to make jigs for cutting small and large circles http://www.wealdentool.eu/rf_tips/rf_tips_04.html
This sounds good - but I don't know how to create the counter slots. The write-up refers to
two counter-slots (made with a guide bush guide)
but that presumes a knowledge I don't yet have. :)
You don't need to use a guide bush. The slots are cut by plunging the router right through. The counter-slots can be made by using a wider cutter or by making several passes with a narrow cutter if you don't have a wide one. You can position the cuts by using the fence on the router or by running the edge of the base along a straight edge.
Cheers :wink:
Paul
Ah I see - I have a router table - so I could easily make the slots on the table yeah?
I wouldn't because you would have to lower the workpiece onto a revolving cutter. I would stick the workpiece onto a sacrificial piece of MDF with heavy-duty double sided tape and use the router hand-held, plunging it into the work.
Cheers :wink:
Paul
How many, what material and what do you want to do with these discs?
If just a few I'd do them on the bandsaw around a pencil line and then tidy up with hand tools.
