stephenharris
I own a (Katsu) palm router, and in order to cut some groves to take 5.5mm ply, I bought a 7/32" slot cutter and table insert.
Unfortunately I failed to account for the diameter of the bit (~50mm) which is too wide to fit through the plate (42mm).
I think I might be able to insert the bit after the router is mounted (I haven't yet made the "table"). But failing that, could I use the slot cutter to widen the hole in the plate?
Its a TCT bit, so could it cut through 4mm of aluminium? (it's just the shelf the insert plates sit on that is in the way). It would mean I couldn't use the inserts, but that's OK- the plate was only £10.
Or should I just look for another plate with a wider diameter?
