I did guess as muchgalleywood":2ngv76vc said:If it is direct link the router's collet I would say no as I don't believe the collet has the range.
However if you use it in an extension adaptor that uses an ER collet then I believe it will be OK if the appropriate sized collet is used.
I believe the ER collets have a range of 1mm - so a 12.7 mm collet will accommodate a 12mm router.
Obviously you should check with the extension adaptor supplier if what I am saying is correct.
