Router advise needed
Dalejones
21 Dec 2015
Swansea
ok I have just bought my first router, It's a dw624 now I'm looking for some bits to start me off, can anyone recommend a good starter kit, I was going to get myself a worktop jig and some kitchen bits to get scribing work tops but I know there is so much more I can do! Thanks advise is welcome
Trend sell good starter kits which give you a nice selection of bits, great for just playing around.
You'll generally just buy the bits you need for a specific job and gradually build up your router bit arsenal
Thanks for the quick response, yer I have noticed trend are the top brand for bits, where is the best place to buy bits? Cheers
As Adam said, a Trend starter set will be OK. Not the cheapest you'll see but they are reasonably good - I have one of their 1/2" sets. You'll have some cutters that you may never user in anger but you will have plenty to learn with. When you have specific projects you'll probably need some specialised cutters. Re: worktop cutters, many cheap ones are just that cheap and not great. They'll do one project, that is half a dozen cuts or so before needing sharpening or replacing. Worktops are cruel on cutters. And remember, not all are suitable for plunging (deep morticing).
EDIT: for Trend, try trenddirect.co.uk or eBay. Trend Professional range are better than the craftpro ones but more expensive
The Trend starter sets are good. Wealden are excellent to buy one at a time as you need them. Look at item No. 272077682872 on evilbay - a useful bearing guided cove cutter from Trend for £3 inc. p&p.
It's all about what you intend to make. There's no such thing as a "set" of router bits in the way you can get "sets" of spanners or drill bits.
A full time kitchen fitter might buy double flute 1/2" cutters in packs of ten but would never need an espagnolette cutter. I get through template copy bits like they're going out of fashion and I'm happy to pay a lot more to get a tiny improvement in how clean the cut is, for someone else that's a waste of money.
Think projects first then tooling second.
Good luck!
Got 6 oak boards the size of A4 paper by 12mm thick and need to reduce to about 7mm thick
Don't have a planer/thicknesser :cry: might try my HITACHI M12VE router
What would be a good router cutter to use ?
Also, is it possible to do it with router in table ?
I would use my 1 1/4 mortice cutter and my route on skis for that. If you were to use a table you'd need to suspend the workpiece in a frame above the cutter and in use you'd not be able to see the cutter which is always less than ideal
Cordy":25dp91j2 said:
Thanks for reply mseries; do you mean something like
This
No, I use the 1 1/4" one from here http://www.cmtutensili.com/show_items.a ... ~7/8/901~2 this one actually 801.317.11 It doesn't need a depth of cut but wider cut is better, those specific morticing bits have different chip clearance for end milling, otherwise a straight cutter with end (plunge) cutting would work well enough.
There's something to be said for trying to do as much yourself as possible but I would say in that instance, I would find someone local to you with a decent size planer thicknesser (and preferably a large drum sander) to thickness it for you for a reasonable sum of money. I would expect to end up with a better result and much more quickly.
If you do want to go the route of routing it yourself to thin it then you'll need to make yourself a nice sturdy jig and make sure the depth/height lock is solid with no play in it. Otherwise you'll spend an eternity flattening those little holes out afterwards!!
Cheers Adam; no way can I ask for physical help with boards !
They started off at 25+mm but my ankles played up so had to stop for a while; I was using a hand plane
Need physio now for ankles which are improving
Just started to make a sled; designing as I go -- I'll make it robust
Swansea: :lol:
Wigan; a small town in Lancashire
Although my heart is in Llandudno, would love to have a holiday pad there but sadly Mrs C doesn't share my fondness of North Wales
Only a beginner at woodwork, retired gardener
Made the jig and done a trial -- scraped down to 9.5 mm approx., decent finish
Will tune up and crash on tomorrow
Making place-mats with inlay using scroll-saw
Mseries;
Early this morning I ordered CMT 801.317.11 Mortising 0.5 inch shaft
from Amazon USA
Delivery 7th January
