MikeG.
Stick to Record, Stanley, Marples or Clifton. Don't waste money on Silverline.
Impossible to say without knowledge of the general standard of Span planes. And while it looks okay to me any brand can have individual planes that are sub-par so buying on ebay is always a risk.julianf":1fsx03yx said:Would that be preferable to a cheap silverline from toolstation? Theyre about the same price, all in - ie about £15.
julianf":36n39nu8 said:So a scan of ebay shows this -
Very good. It is great to see some definite reasons why one plane is not so good as another rather than subjective comments amounting to "it feels better". I have never understood why it would be better to go for an expensive plane rather than a cheapie, and these comments give me some idea. However, I did not understand what you mean by "two part yoke for the depth adjustment". Can you clarify that please?Mr T":1phlbpto said:The plane pictured has a couple of features I would avoid. Firstly the pressed steel adjustment lever, this often becomes worn at the blade end making adjustment difficult, secondly the two part yoke for the depth adjustment. Sometimes the parts can come apart, again making adjustment difficult.
Just4Fun":ktcdcf48 said:However, I did not understand what you mean by "two part yoke for the depth adjustment". Can you clarify that please?
julianf":26rw7fif said:Thank you.
And for my next question -
When im looking on ebay, i see items advertised as "smoothing plane", and some as just "plane", and others as "jack plane", and, to the untrained eye... well, im cautious as to buying the wrong thing.
Is there a specific feature that makes a unit a "smoothing plane" that i can look for?
Not to be contrary but I have to disagree that this is a feature that you should use to rule out a plane. Yes the two-part steel versions were most definitely a cost-cutting measure when introduced, but they've been around for a very long time now and have proven themselves up to the job. And even though they can separate as Chris says this is easily fixed with one drop of glue, and I actually don't think they're the inferior choice. In fact they have certain advantages over (most) cast ones in that they're not a brittle material so there's some scope for adjustment to reduce what is called 'slop' or 'backlash' in the Bailey mechanism, if you wish to do so.Just4Fun":1adqaxk7 said:Very good. It is great to see some definite reasons why one plane is not so good as another rather than subjective comments amounting to "it feels better". I have never understood why it would be better to go for an expensive plane rather than a cheapie, and these comments give me some idea.Mr T":1adqaxk7 said:The plane pictured has a couple of features I would avoid. Firstly the pressed steel adjustment lever, this often becomes worn at the blade end making adjustment difficult, secondly the two part yoke for the depth adjustment. Sometimes the parts can come apart, again making adjustment difficult.
The leading edge? That does matter if you intend to use the cap iron to its full potential.julianf":9or5yuxl said:The cap iron is a bit rippled, but i doubt that matters.
That hardly matters to any user, regardless of skill level It's really only a cosmetic issue.julianf":9or5yuxl said:Apart from a bit of a chip on the edge (which i hardly think matters to someone of my skill level!)
Seriously?? This is what puts me off buying stuff sight-unseen!julianf":9or5yuxl said:The ebay seller is ok - his ad stated "no pitting"
julianf":1blxf4ym said:im just not experienced enough to know!
Mr T":28p1a941 said:That pitting is pretty heavy, the blade is fairly short. I would suggest asking for a £10 refund and using it to buy a new Stanly blade from Axminster. You will need to check the new blades when they arrive though, I sent back three out of five last month because they weren't flat enough. Working a bevel on the back to get round pitting just makes life complicated later.
Chris
Careful what you read on the Internet :-D Yes there's lots of this about, and two very influential figures on the American side of things, Frank Klausz and Michael Dunbar, shared this view and together may be partly responsible for how commonplace the opinion is now in the US.julianf":2l097kdg said:I watched a bunch of youtube vids, and looked on websites and the like, and the general consensus seemed to be "some pitting can be dealt with, but too much, and you may as well find a better unit"
Well, this isn't too much:julianf":2l097kdg said:But, being a novice, i dont know how much is too much!
Yes that's fine. I have a good number that are extremely heavily textured (on both sides) but work fine.julianf":2l097kdg said:The cap iron is rippled along its back, but not at the folded end that makes contact with the blade so id think thats ok.
Well a misleading description is a misleading description. I got a partial refund years ago on something because the seller (who later tried to plead ignorance) stated something in plain English that was simply not true. If they'd kept mum and not tried to over-egg the pudding they'd have been fine.julianf":2l097kdg said:The seller has actually offered me a partial refund, but my take on these things is generally "if its fit for purpose, then its fit for purpose, so a partial refund is wrong, but, if its not fit, then a partial refund wont pull it out of the scrap bin" if you see what i mean.
