HamsterJam
Let’s take it apart to see what’s inside….
I ring too - we don’t have rope heaters though.Live and learn indeed! There's a whole world of campanology out there, awaiting discovery...
I was pretty sure there'd be another ringer here!! You may well not need rope warmers (or driers) - but we proudly hold the prize for "The Coldest Ringing Chamber in Yorkshire"!I ring too - we don’t have rope heaters though.
All I meant there is to fit the resistors vertically up the enclosure. I just noticed it's wooden, so it would have to be replaced by a proper fire enclosure. Still reasonably easy to do, but I see you bought a ceramic heater.... vertical array ... Lost me there, I am afraid.
Foam pipe insulation would simply prevent the ropes from drying. They would take a long time to put on and off too.What about that foam pipe insulation ?, you know the type, its silver grey tube with a slit up one side. You could put it on and slide it up,get to the end(I think they're 6' lengths, then add another which in turn pushes the first one further up, till you either cover the entire rope, which I dont think is practical due to the height of some towers, or just the lower ends the bell ringers hold.
Or someone walks up the tower, unhooks the rope, drops it down to be stored somewhere warmer, then repeats the process in reverse. Has to be better than heating an entire tower with the price of energy soaring as it is.
The whole thing was interesting!The second paragraph in this article might interest you @WoodchipWilbur Mud on the dog, blood on the ropes
I have a keen interest in all things sharp and the use of ropes. As a pre-teen I once snook into the bell tower in the Dronfied Parish Church and rang one of the bells. I then ran like The Devil was chasing me. I also like flying buttresses and stonework too. Oh the list goes on.
The heater needs to fit into the small chamber at the bottom, below the metal grid that keeps the ropes themselves away from the heat source. Note that it already works well. It doesn't "heat an entire tower with the price of energy soaring as it is". Not noticeably, anyway!In our cold and damp bell tower we have a rope warmer that dries out the bottom ends of the ropes so they are flexible enough to use. It consists of an octagonal ply tube, 200mm diameter and 1.5m tall with 2 x 100w incandescent bulbs in the bottom.
It works well.
These are excellent, often used in lift shafts and motor rooms to keep the damp at bay, I use them in mushroom sheds, 40W version on solar, lots of different makes, sizes and powers available. With the thermostat they won't get too hot, I don't know what the temperature limit for bell rope is but ours you can hold to warm your hands so I would think they were OK touching the rope. Don't know if that negates the rebuild. Don't send me the bill if I'm wrong.Will a greenhouse tube heater fit? Dimplex Thermostatic Tubular Heater IPX4 2ft 80W (toolstation.com)
I have a smaller version fitted in hall cupboard that has an outside wall. They also have a built in thermostat so only come on when needed.
Colin
