Paul.J
Started making my latest Rocking Horse this week.It's been about 4 years since i made my last,strange how you forget things when they are not done on a regular basis.
Had the timber delivered from Whitmores who were very helpful,and will use again if needed.
Timber is 3" thick Tulipwood for the main body,and 1-1/2"Beech for the legs.All will have to planed down to size,with some re-sawing of the Tulipwood for some of the body parts.
I'm afraid it looks as though there will be lots of piccys so i hope you don't get too bored with it,as it will probably go on for a few weeks.So here goes :roll:
Click on images
This is the timber.
The Tulip was originaly a 13'x12"x3"piece but i had it cut in half.
Then i marked all the body parts out and cut this into smaller more manageable sizes.
This is the Tulip planed and been marked out ready for cuttting on the bandsaw.
Head been cut out.
Then i cut a 10 degree angle on the back of the head to give the effect of the head been pulled to one side.
Set the 12" sander to 10 degrees to get a nice flat surface.
Then i drilled 2 10mm dowel holes in the middle.
Placed the dowel markers in the holes.
Then placed head centrally on the neck to mark the corresponding holes,which are then drilled out.
Put plenty of glue in holes and on surface.
Then clamped the head to the neck,after checking first that i had a good join.
Then marked out the ears on an off cut.
The ears are 12mm thick so they were cut on the bandsaw to thickness.
Then the ears were also glued and clamped in position.
The head as now dried and i have been carving it,i will post piccys of this tomorrow.Looking good so far :shock:
Click on images
This is the timber.
Head been cut out.
