Harrison85
If you plan on turning something that big Mark can you take some pics please!
Dan
Dan
There's also the proper tool Looks like a wedge with a slot cut in the middle the same width as the morse taper diameter. Put wedge between spindle nose and back of spur drive and tap the thick end with a small hammer, and out it pops. Easy peasyTony Spear":2xytujxm said:Don't it seem strange that somebody should go to all that time and trouble to design and make a piece of kit like that and then leave the user to fart around with Stillsons to get the centres out?
I suppose to do it the conventional way with a slot through the spindle to allow a wedge to be driven through behind the end of the taper would need too much spindle overhang?
Tony Spear":7jae18il said:CHJ":7jae18il said:Richard Findley":7jae18il said:.....Like Wallace, I just use grips to remove centres. They are starting to look a little scruffy now, one day I might take them to a local engineer and have some spanner flats machined onto them.
Pity you can't get a so called 'thread protector' to fit your spindle nose, it could then be used to jack out the morse taper centres.
