rise and fall on a hammer saw
williams1185
23 Nov 2010
neath
hope this helps others with similar machine had a problem with saw not reaching max height depth of cut was shy by about 20mm spoke to felder helpful suggested cleaning threads on rise and fall with lube and a brass or nylon brush could not sort it at all was stiff at upper limit so after phoning them again agreed to new parts and technician so all up would cost around 750 inc vat ! so tech turns up does the same as i did lube clean etc just by luck with the blade off and saw tilted around 22.5 degrees i spotted the rise and fall quadrant behind the dust chute not easy to see spotted the bolt moving up the quad and noticed dust jammed above the bolt it was really solid machine is 13 years old so took all that time to build up bit of lube and pointy tools sorted it ! expensive lesson though still cost about 300 !
