i certainly won't argue with tensioned blade bit, i suspect that's why i'm fond of these saws in the first place.
not sure that tooth profile is a secondary issue though. at this point i have three blades for this saw, the two bodged from band saw blades and a Bahco greenwood blade that i bought years ago. lately i've been trying these on all sorts of stuff in my garage shop, swapping blades freely on everything from green oak to the seasoned oak rounds to some old spalted beech to bucksawing up a big beech tree that recently fell nearby. no way would i say that tooth profile is insignificant or even secondary. also using the Predator and Barracuda described up-thread. oh, and a Japanese double-sided (softwood) Ryoba saw as well.
each of the blades behave differently, as you would expect, and some blades are definitely better at certain jobs. in no particular order:
- bucking up the green fallen beech: the Bahco greenwood blade easily the best. The Ryoba cross-cut side is brilliant here as well. the Barracuda was also good.
- ripping the cuttings from that fallen beech: easily the bodged 6tpi bandsaw blade is best. Ryoba rip-side very good as well.
- ripping green oak: same as above, no surprise. cutting green wood doesn't vary much from one species to another IMO. interesting note: the panel saws were terrible on greenwood ripping (sloppy kerf, clogging, ragged finish, etc).
- ripping the seasoned oak rounds: the blades bodged from bandsaw blades would be my preference. 6tpi first, the 10tpi a reasonable second. both considerably better IMO than the panel saws. the Predator was okay, got the job done but it wasn't pretty and not much fun (a lot of chatter).
- the spalted beech: this was a tough one, especially ripping. perhaps because the spalting has somewhat broken down the grain? the Ryoba was probably the best here. the bodged blades were a bit better than the others but none performed especially well. not sure what to make of that.
given the shear versatility of the Ryoba -- crosscut on one side, ripcut on the other -- i would very much like to try a hardwood version on some of these cutting jobs. someday soon i hope.
so my take-away from this is "try things" and go with what works best. amazing insight, i know.
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
i'm not finding there to be any "this is better for everything" candidates here, nor did i ever expect there would be.
