whiskywill":1xji4g0m said:paulm":1xji4g0m said:Sounds like you need a couple of goats !![]()
Unfortunately, goats are not great grazers. They prefer the leaves and bark of your favourite shrubs and trees.
browsers not grazers
clanger":rnj3wngf said:As Bugbear says, you will spend a lot of the time turning when going around trees etc. The other option to getting a wider deck (which has it's own problems of manoeuvrability, access etc.) that I have is a Zero Turn. When you get the hang of them (about 15 minutes) you will find yourself flying along. I have a second-hand Toro Timecutter and wouldn't go back to a "normal" steering-wheeled mower.
Chris
Not according to my reading of a couple of articles yesterday.Mark A":3pglyjgg said:Bugbear - I assumed with their lower center of gravity a zero turn would be better suited to slopes than a conventional ride on mower?
Mark A":r5mb9dav said:I think I may have convinced the treasurer to increase the budget, meaning I can now skip the 30-year-old rust buckets and look for something a bit newer.
llangatwgnedd":19z78cxi said:Very cheap to run.
