Hello people,
When Covid started I decided It was a good time to scratch the itch and finally get my first and last lathe! I’m only interested in bowls etc and short Graduates are rare and seem to go for big money. So two years later I’ve finally got a Viceroy TDS6. Paid £500 for that + Record BS250 delivered.
It arrived on Sunday. The seller did not seem to know much about it but it’s an ex-school machine and seems to have had a fairly gentle life. Thanks to Farmer Giles here and a restoration thread on the Denford forum I had some idea how to get started and spent most of yesterday taking it to bits. Unexpectedly the cabinet was welded to the base so everything had to come through the door.
Now the questions……
I knew chuck options were limited but I had to Google Burnerd and I’m not sure this chuck will be user friendly. I want to keep the chuck as close to the bearing as possible. I had previously discussed with Ian – flh801978 on here- the possibility of machining the spindle to 33mm but now I see one in the flesh I’m not sure there’s enough metal with the 3MT socket. Axminster no longer supply the SK114 @ 1.5" x 8tpi. Is it feasible/ sensible to buy one anyway and bore/tap it out?
I will get the kit from Newton Tesla for VFD as the motor is 1hp and seems fairly new. The belt rivets are rusted/oxidized and I chopped them out. Is this - PowerTwist Plus A/13/4L High Performance Composite V-Belt 13mm Width Simply Bearings Ltd a good replacement? I don’t want to take out the spindle and intermediate shaft if I don’t have to.
Finally - for tonight at least - the paint is in reasonable shape – just needs a bit of filler and rubbing down. I assume this is the original colour and I would like to keep that. Does it have a name/RAL number?
Any and all info and advice gratefully received.
Now the questions……
