Cheers Vann, I guess my question is then… if you had a dedicated: Scrub (for shaping the board), Jointer (for achieving flatness) and Smoother (for finishing), what would you use the LA Jack for? Would I be right in thinking it’s for the stage in between the Scrub plane and the Jointer? Or would the Jack end up being used as a scrub? If so then, as the video review mentioned £200 is a lot to spend on something that won’t be required to put anything close to the finish on a board… I might as well buy a decent smoother now and spend a bit less on a 2nd hand Jack to be used as scrub. But if you think that even after getting hold of a Scrub, Jointer and Smoother I’ll still have use for the Jack then I’ll definitely go for it
Gary, I don’t think it’s fair to say I’m buying tools blindly, I’m here speaking to people with experience as there’s little else you can do to know what you will need in the future - I can’t say how often I will use a particular variety of tool when I don’t yet own anything of it’s type! Previously I’ve made a bookcase and a few small bits and pieces, next plan is to make a blanket chest… I prefer the idea of using reclaimed timber or even drying my own green wood (where available) so know I’ll eventually need a range of tools required to take something from large stock to usable board
