shad3925":2csf0xnv said:
Hi Jon
Many thanks.
I went to Axminster"s Warrington branch last Saturday ( Three local clubs were giving turning demo's), whilst there Matthew the assistant manager (very helpful) was very enthusiatic about the Numatic NVD750, are there huge differences between this model and the CGV286.
When using these extractors with your lathe when sanding is a special adapter needed or is it just placing the hose in a convenient place near to the sanding.
Reg
I have the NVD750 and yes, it's the twin motor one. It's excellent, the suction on the 4inch pipe may be a little on the low side, but then I've never used any other machines for my own ends, it's not a chip extractor, and a four inch pipe is a heckuvva wide pipe to be sucking through, so it may just be my inexperience talking there.
In order to use it at the lathe, I have a very MacGyver trick, I duct taped two very strong half inch Neodymium magnets to the nozzle of the hose. I attach this on the underside of my toolrest,nearly touching the workpiece, wherever is in the best position to grab the majority of shavings as I work. It doesn't catch everything, especially the larger chips, but seems to grab a great majority of the finer stuff. I have one of the thicker and flatter toolrest designs, so I'm not sure it'd work for you if you use a round bar one.
For turning I'm not sure of a better way to use it. I've seen folks use the 4 inch hose just mounted behind the workpiece, and others using a perspex hood. I don't think either would prove superior, but they might be less fiddly to use.
The magnets under the cushioning of ducttape makes for great grip and slide resistance, I've even used it attached straight under the bandsaw table, sucking the waste straight through the table insert under the blade, while cutting stuff I *really* didn't want blowing all over the workshop.
Can't help you much on the actual respirator tho. I'm yet to find one I'm happy with myself. The trend airshield was too heavy for me too and I also found that the angle the air came in (just above your eyes) made for irritated eyeballs after a while. Do the JSP caps avoid this? I've been using good quality P2 paper masks under a full plastic face shield until I find a better option that is affordable.
All the best in your hunting.
Nic.
