I bought one of these recently to attach to the back of our little dinghy:
https://www.amazon.co.uk/gp/product/B002FVP7SC/ref=ppx_od_dt_b_asin_title_s01?ie=UTF8&psc=1
Reading the regs, the lights aren't close enough to the width of our trailer, so they need moving further from centre. I have a longer wooden board that I'll attach the lighting board to, move the lights further toward the edges of the plastic lighting board, and place the triangles and fog light onto the wooden board.
That leaves inadequate lighting for the number plate (the light for the plate comes from the tail lights, a clear lens toward the plate). So I bought two of these, which I'll connect above the plate.
Question - do I simply connect the red and the black wires to the red and black wires (the tail light bulb) here?
And at the other side, does the red of the number plate bulb connect to the 2x red cables, and the black connect to the brown?
I think the question is more about whether this will work in principle - will the number plate lights come on when the tail lights are on? I really don't get electrical circuits. But also I wanted to check the connections are as I've described.
Thanks, Chris
Thanks, Chris
