JoeSheffer
Currently helping convert a horse box into a studio flat on wheels. There are about 600 screws that we are pulling out of the sapele planks which make up the box, which screw into the ash frame. They're imperial screws of 5.5x55mm ish so i assume a 6mmx60mm replacement would be fine. The heads are not going to be visible in the finished project and the screws will be replaced as many are rusted/broken.
I have always found screwing into hardwood surprisingly difficult, and in my joinery don't tend to use screws beyond hinges etc. I wonder whether you guys think there is any reason not use a screw like this:
https://www.fastco.co.uk/6-0-x-60mm...MIxJDZmI_47QIVaoBQBh1LUgQ8EAQYAiABEgKnmvD_BwE
Are stainless steel screws a good idea for this project, or is the above fine? Must I use a partially threaded screw or would a fully threaded screw - i assume a partial thread is a must to pull the boards back on tight?
