Jacob
What goes around comes around.
I swear you just misunderstand it on purpose as you go along! It wants to be in line, even the very tiniest gnats testicle amount forwards so that the back of the blade is in definite contact with the mouthwoodbrains":izevtrap said:Hi,
So now the sole isn't slightly forward of the frog to provide contact in the bevel. I swear you just make it up as you go along.
Er - well they seem to be by and largeIt is highly unlikely that this portion of the rear mouth opening is even in the same plane as the frog ramp anyway,
For one plane yes a good idea. Convert it into an uber smoother. A no4 ideally? Or buy a LV la smoother, which is what I did. Or get by with scrapers. Stanley 80 is good. Hand-held bits of old saw blade will do it.unless you take the trouble of some fettling with a file, etc. and let's face it you haven't done that, either.
A 3mm thick replacement is nearly 3 1/2 times more rigid than a standard one so doesn't require any dubious frog setting so you can close up the mouth like you should to prevent tearout without fear of chatter. Couple this with a 2 piece cap iron which doesn't curve the blade when you nip up the cap screw and you have better frog contact and even more rigidity. Can't see the downside nor any reasonable argument against.
Mike.
One uber smoother is enough . No point in converting all your planes into smoothers! Madness, expensive and you lose the thin blade advantage of ease of sharpening.
