Molynoox
thanks. I wonder how easy it is to remove the old one :-D
Do you happen to know if there is any difference between the B-07353 that my SP6000J came with and the B-09298 I have just bought to replace it? The new one says Specialised as per your table but I wondered if that is juat a rebranding thingThe very thin ones are aimed at the cordless tracksaws, with corded you can use the thicker blades. This info may help, keeping track offset the same will not impact the tracks rubber.
cutting speed M/sec Thickness TPI Teeth Kerf mm Hook Makita 44.92477495 Offset for using track B-07353 165 1.6 2.352021 48 ATB 2.2 8° 0.3 B-09167 165 1.0 1.17601 24 1.5 20° 0.25 Cordless plunge Specialised B-09173 165 1.0 1.17601 24 1.5 20° 0.25 Cordless plunge Specialised B-09260 165 1.6 1.372012 28 2.2 23° 0.3 Specialised B-09232 165 1.0 1.960017 40 1.6 18° 0.3 Specialised B-09276 165 1.6 2.352021 48 2.2 8° 0.3 Specialised B-09298 165 1.6 2.352021 48 ATB 2.2 8° 0.3 Specialised B-09307 165 1.7 2.744024 56 2.4 -3° 0.35 Specialised Aluminium B-56699 165 1.4 1.372012 28 2.00 15° 0.3 Cordless plunge Specialised B-56708 165 1.25 2.352021 48 1.85 8° 0.3 Cordless plunge B-56736 165 1.4 2.940026 60 TCG 2.00 5° 0.3 B-57320 165 1.0 2.744024 56 1.45 23° 0.225 Cordless plunge Efficut B-57342 165 1.0 2.744024 56 ATAF 1.45 23° 0.225 Cordless plunge Efficut MDF B-62979 165 1.0 1.225011 25 1.4 23° 0.2 Efficut
They don't give much details for the CMT blades but for more detail look here
Hook angle so you know it is suitable for a tracksaw or at least some mention that it is suitable because the company cannot be bothered to show an image of the actual product being sold. Look at the info provided by that American company, they give a full description and state it is suitable for a tracksaw, not all blades are.
Hi,
