I won a Stanley mitre box on ebay recently, and when it arrived the courier had bashed it about sufficiently to crack the angle adjustment mechanism in two places, one crack either side of a hole which fits round another part, and thus it's important to maintain the dimensions closely. I could do with advice on how to repair this as it's outside my area of expertise.
As I understand it I can use Brasing with brass, TIG welding with high nickel content rods, Use an oxidising flame to burn off the surface carbon and then silver solder, or use a structural epoxy or cyanoacrylate adhesive with a metal filler.
My temptation is to use structural adhesives as I'm more experienced with them, and if it fails I can always burn them off during preheating for welding or soldering if it comes to that.
Final option is simply to make a new one either by sand-casting using the original as a pattern, or machining it from steel.
