sploo
Somewhat extinguished member
I only have one of the cheap gasless MIG welders (and a level of talent with it that needs a grinder and paint afterwards), so I assume trying that would be a really bad idea.
The hardest thing about TIG is keeping the tungsten gap constant and feeding the filler rod in which is like a dipping motion, much easier if you have gas welding experience. TIG is the ultimate welding process, all positions, any direction and so easy to join thin gauge material to much heavier gauge so a process worth the practice. You also want HF start and cleanliness, acetone is a great cleaner for TIG welding and don't wear heavy welding gloves, just lightweight gloves and if using a watercooled torch then wrap the cables round your arm for added support.especially when it comes to Tig which is a steep learning curve
My brother, before he passed, was a reasonable welder and he managed to weld a broken cast iron coffee grinder handle back together using a technique he called sif bronze welding, or at least that’s what it sounded like. It was very successful and the grinder is in use to this day. Sorry, can’t ask him for any further details!!I've got an old #4 1/2 hand plane that has some sentimental value and I'm trying to restore it to an at least reasonable aesthetic condition.
Some of the side is snapped off and long gone (see pic):
I've seen many brazed plane repairs over the years, but always using (what I assume is) brass rod; and I don't like the obvious colour difference. If I were to get some cast iron and machine it to an appropriate shape are there silver/grey brazing rods I could use with a MAPP torch, or would a "normal" plumbing solder be strong enough to hold a new part?
That's ideally what I want to avoid - though I accept it may be easier said than done.Broken planes used to be repaired by brazing.
The plane would be perfectly functional but you’d have a bronze coloured lined where the break happened.
That was done by time served welders, it’ll be strong and functional, you’ll have to turn the repaired side towards the wall if you want an ornament though.That's ideally what I want to avoid - though I accept it may be easier said than done.
