SandyMat
I was fortunate to pick up a variable speed Hegner Multicut 2s at what I though was a good price locally. On getting it home I found that the variable speed control made no difference and it seems to operate at one speed only. I planned to use some compressed air and electrical cleaner to see if it was simply clogged up contacts but I've been a bit heavy handed and the control knob has now broken off!
At least the machine is useable as the running speed is perfectly workable.
However I'd ideally like to get the variable speed working again. Hegner want over £140 for a replacement speed control box which seems very expensive. I can continue using it as a single speed, or pay Hegner, is there any other option to repair/replace the speed control box?
Thanks for any advice.
