Do you still have only one plane Mike,
Or do you have an extra cutter and cap for it?
I wonder how would you be able to come to that conclusion, if you have never had another plane to try
I find it strange if your on a woodworking forum often, to share and learn, like we all are ...
but not try any techniques like the use of the cap iron as in David W's videos?
No mysticism, its clear it works, and is clearly the best way to plane, regardless if you have your way that you do it
the cap iron will dictate otherwise.
The best smoothers are double iron planes, which means...you use the cap iron for it to have influence with the shaving.
Put it this way...
With a reasonably thick smoother shaving, if you have more than a hairs camber on the blade, the cap iron will not have influence,
and you will get tearout
Maybe not if your someone planing agreeable instrument grade softwood,
but for the most of us, that gnarly piece is just around the corner.
A smoother has the cap iron set ready for this or anything else you can plane, it will never give tearout.
I found it amusing on the last thread, how many people refuse to use, or believe that a cap iron setting shaving ,
changes the way you plane, as you dont have to worry about diving the plane off the edge
Its nothing to do with technique, anyone who says not, has not learned to set the cap iron correctly for a smoother.
Tom
