Removing Spray Adhesive From A Float Glass Lapping Plate
Synthetic thinners like what is used to thin enamel paints, I get it in 5l tins for when spraying machines. It dissolves any glue residue and pretty much any paint or plastic. Just don't get stuff marketed for hammerite as that's the same stuff but 5 times the price
YorkshireMartin":kafveid4 said:
99% Isopropyl alcohol will dissolve most adhesives and leaves no residue. Otherwise, acetone, as already suggested but I was under the impression acetone had been removed from nail varnish removers under EU regs? I stand to be corrected on that, but certainly the brand my wife uses is no longer acetone based.
Incidentally, isopropyl is unbelievably good for cleaning stainless steel in the kitchen. It literally just melts grease. Our cooker and extractor has never been so shiny. Only downside is, you really need to remember to open a window because it doesn't half give you a headache if you forget, like I did. lol.
£7 a litre is what I paid recently.
Get someone to split with you.
https://www.amazon.co.uk/LITRE-Pharmace ... yl+alcohol
