Removing Sadolin Wood Stain from brickwork
JBaz
22 Jun 2020
Ratcliffe on the Wreake, Leicestershire
The decorator has spilt some Sadolin Classic wood stain on the facing brickwork of our house.
He wiped it off immediately with white spirit, but it can still be seen.
We have tried pressure washing but it hasn't moved. We have also tried acetone and paint remover (on some test bricks I have spare) but that didn't work either.
The decorator is insured so I'm looking for either a method that is known to work or a specialist who who does this sort of work.
Any ideas?
If it was horizontal you could cover it with crushed cat litter, ( a lot of it is "fullers earth' which is wonderfull for absorbing oils out of things like brick surfaces ) maybe rig up a box ( or plastic cover with the stuff sealed against the brickwork behind it ) to do so vertically.If it was stonework or statuary that is what I'd do. Sealing it from rains while it works is the tricky part.
White spirit, and if that fails I’ve found that Tetrosyl Gun Wash GUN025 shifts just about anything! Not a nice substance but cleans cellulose and 2K as oil based products.
I ha
I have some spare bricks that I could try this on. If the cat litter removes the stain (now that it has dried) I will bear it in mind, but as you say, keeping it against the vertical wall and dry could be a challenge.
Could work. I have cellulose thinners so I'll try that on a test piece first.
My concern is that some chemicals may themselves discolour the brick so I end up having to treat the whole face.
I suggest trying a bleach solution on an old brick, then rub the brick with another bit of brick to bring back the colour.
The product is likely to have a Material Safety Data sheet on the manufacturer's website. That will allow you to see what chemicals are in it. That could guide you in the choice of a chemical to treat it.
When the product is applied to wood, how does it degrade over time? If it fades in sunlight, then some UV lights shining on the wall might artificially speed up that process. UV light is not good for you so proceed with caution.
The difficulty is that if the only practical method is to replace the bricks, that will be more obvious than the current problem.
The problem here is that the initial attempt to remove it probably made matters worse. The bricks and mortar are absorbant, so the solution just seeped in deeper.
I had a similar problem years ago. I wanted to built a new fireplace with old bricks. I wanted the brickwork to be a feature but many were stained with soot. My solution was to paint over the stains using brick dust and PVA. I varied the colouring by taking dust from differing bricks. The dust was obtained by boring with a masonry drill.
Here is the result:-
The bricks behind the stove are completely faux. They are just 'paint' on concrete blocks.
Brian
